I´m currently repairing a monitor for a colleague and what I thought was an easy job became a bit more difficult ... She bescribed the "usual symptoms" - the screen goes blank a few seconds, then restarts, flickers in back light on/off, well you know what I mean
It´s a Viewsonic VP191s monitor from 2003 I think.
After replacing all the capacitors (none bulging or leaking) I thought I was done, but no ... The startup problem is still there! After some research I discovered that the power supply wasn´t delivering the 12V required but if I waited for like 30 seconds it did. All the capacitors on the power supply (except the SMD) are replaced with Rubycon ZLJ, one Suncon WX and one Rubycon KXW (primary cap). The capacitor for the PWM is probably a SMD since the whole chip is and there´s no obvious "47 uF 50V" on the board.
To make a long story short:
I believe the problem is the optocoupler for the feedback circuit on the power supply and would like to at least try to replace that. The problem is that I can find ANY usable information what to replace with ...... Sorry for not having any pictures (the unit´s at work) but nevertheless I can read out it´s a L-4050 optocoupler.
The power supply is manufactured by Tiger Power and the model no. is TOF-5001 Rev 0E, part no. 44.61103.002
Perhaps there´s some generic part that will do? It´s a 4-pin DIP circuit.
Thanks!
Edit: mistype
Thanks!
Edit: mistype
