IBM pc8394 tools
    Re: IBM pc8394 tools
    thanks
      Thanks for the program
        Perfect!!!!
          thanks
            thanks
              Thank you!
                When I use PC8394T.rar to get T43's password,there ara some error .help me
                Reading device...
                >err1:168:128
                err2:168:168
                  Hi there,
                  has someone a nice picture of the wired circuit? Got some problems with the diagram.
                  Thanks in advance,
                  hagler
                      Hello badcaps!
                      Questions relating to the removal of the password on my IBM T43.
                      I have built a modem with max 232 as shown and downloaded the necessary software
                      How to understand when the manual says :
                      Keep the probes firmly connected to the board marks while you execute the reader: rpc8394.exe filename.bin, where filename.bin is the file where data is be stored.
                      Does that mean that you just start the program file rpc8394.exe?
                      Is the program then managing the modem, giving the file a name and saving it?
                        Originally posted by Hurup View Post
                        Hello badcaps!
                        1- in dos prompt for example c:\program_directory \rpc8394 save.bin
                        2-plug the "modem" cable in serial port
                        3-connect the probes firmly to board marks .
                        4-press enter
                        5-use ibmpass to decrypt save.bin and reveal password
                          Thank you very much for your guidance
                          Just read the instructions now and must admit that I had not seen it as a dos program!
                          I usually use PonyProg or similar.
                          Will now try to read data from T43.
                            thank you for the cracked version.
                              it says a message device not found, wirh max232 i2c programmer made. any idea i appreciate.
                                Hello, I have the same problem as you, i use a SimpleI2C programmer, but when i try to read the program says ERROR DEVICE NOT FOUND? What can be wrong?
                                  Originally posted by camelion View Post
                                  PC8394T_setup.rar cracked ok see attached
                                  I can not download this zip file I dont understend why? Please help.
                                    maybe its because of the server change give it a few days and try again if i was you.
                                    https://www.badcaps.net/forum/showthread.php?t=51582
                                      The attachments seem to have been restored. Thanks for the program. Would it be possible for someone to dump a clean file for the T43 laptop (from PC8394 chip) for me please? I dumped mine but the password cannot be revealed for some reason. Looks like it's somehow corrupted. If I manage to get a working dump i'll write it to the chip with wpc8394 and maybe it will work.
                                      Thanks in advance!
                                        شكرا للبرنامج
                                          I think I found a good (unlocked) bin file for the T43, but it is on a chinese forum and there seems to be no way to register on it (invitation only). Maybe someone here can download it?
                                          http://www.heimafix.com/plugin.php?i...page&aid=38544
