Hi I have a 3d LG 47" LW 6500. The screen has washed out colors and the menu does as well. I tried replacing the tcon to no avail. Everything works fine and the firmware is up to date. Is it the panel? Any help would be appreciated.
photo negative LG 47" LW6500
Re: photo negative LG 47" LW6500
Looks like bad GAMMA Voltage ref problem in the T-CON board.
Pictures of the back side of the TV?Never stop learning
You have to carefully remove that metal shield to get to the T-CON board. Show us the back side of the TV.Never stop learning
A lot of times these shields are taped down with anti static tin tape or some sort of felt tape. Also they could be stuck to the top of the sponge like chip heatsinks.
Take a look around the shield sometimes they can be surrounding the TFT ribbons so you don't want to yank it off.
Most are only held on by 4-5 screws.
http://www.shopjimmy.com/lg/47lw6500-ua
Hello there. I have the same tv series LW6500 but a 65". One side of screen looks wash out and the other half is black. Disconnecting the ribbon cables from the t-con (wash out side) the whole screen looks perfectly black. I would like to give T-con a try but can't find this board anywhere. Any suggestion on component level repair options? T-Con Part Number: 55.64T05.C04
If any body have the board for sale pls message me.
Thank you guys.
Hi, i have the same TV having the same problem, washed out picture with a single bad vertical line. And i cant find any other posts on this same model. would it be wise to post my photos and steps to this thread? i haven't opened her up yet. but would love to help someone else as reading through some other posts helped me to repair a friends Samsung with a bad IC AS15 chip. or would it be better to start a new thread? thanks for your help!
