Dell 1504FP Monitor Year of Manufacture 2002
    Re: Dell 1504FP Monitor Year of Manufacture 2002
    Tranformer 2 Test:
    Pin 1 to Pin 2 -> 1
    Pin 1 to Pin 3 -> 785
    Pin 1 to Pin 4 -> 1
    Pin 1 to Pin 5 -> 1
    Pin 1 to Pin 6 -> 1
    Pin 1 to Pin 7 -> 1
    Pin 1 to Pin 8 -> 1
    Pin 1 to Pin 9 -> 1
    Pin 1 to Pin 10 -> 1
    Pin 2 to Pin 3 -> 1
    Pin 2 to Pin 4 -> 1
    Pin 2 to Pin 5 -> 1
    Pin 2 to Pin 6 -> 1
    Pin 2 to Pin 7 -> 1
    Pin 2 to Pin 8 -> 1
    Pin 2 to Pin 9 -> 1
    Pin 2 to Pin 10 -> 1
    Pin 3 to Pin 4 -> 1
    Pin 3 to Pin 5 -> 1
    Pin 3 to Pin 6 -> 1
    Pin 3 to Pin 7 -> 1
    Pin 3 to Pin 8 -> 1
    Pin 3 to Pin 9 -> 1
    Pin 3 to Pin 10 -> 1
    Pin 4 to Pin 5 -> 544
    Pin 4 to Pin 6 -> 545
    Pin 4 to Pin 7 -> 544
    Pin 4 to Pin 8 -> 544
    Pin 4 to Pin 9 -> 000
    Pin 4 to Pin 10 -> 1
    Pin 5 to Pin 6 -> 000
    Pin 5 to Pin 7 -> 000
    Pin 5 to Pin 8 -> 000
    Pin 5 to Pin 9 -> 537
    Pin 5 to Pin 10 -> 1
    Pin 6 to Pin 7 -> 000
    Pin 6 to Pin 8 -> 000
    Pin 6 to Pin 9 -> 537
    Pin 6 to Pin 10 -> 1
    Pin 7 to Pin 8 -> 000
    Pin 7 to Pin 9 -> 537
    Pin 7 to Pin 10 -> 1
    Pin 8 to Pin 9 -> 537
    Pin 8 to Pin 10 -> 1
    Pin 9 to Pin 10 -> 1
      Great - wish I hadnt asked!! On the second transformer just measure the ones that T1 has a voltage ie not o or 1
        already did and posted results my friend for both transformers.
        Here are the results of post 12 (VDC200, POWER ON):
        Pin 1 -> 0.01
        Pin 2 -> 0.01
        Pin 3 -> 0.01
        Pin 4 -> 0.01
        Pin 5 -> 0.01
        Pin 6 -> 0.00
        Pin 7 -> 2.2
        Pin 8 -> 2.4
        Pin 9 -> 2.5
        Pin 10 -> 2.8
        Pin 11 -> 2.9
        Pin 12 -> 2.5
          So you did - pity its gone onto the next page. -I will look at the numbers tomorrow
          Voltages are terrible - was there no clue as to what they should be Pson Dim Bl 5v 12v etc If there are can you edit your post and put those descriptions in.
          I am off to bed
            i will look at it tomorrow and post to you back
              Transformers look ok ( Some good at last)
                What are the part numbers on these components.
                I think the next step would have to be changing out all the caps on the 2 boards.
                If you have a 50v 1uf start with that one on the power board.
                  Can the 50v 1uF be changed with something with bigger resistance ? As I don't have one available to just change it.
                  Model numbers coming soon...
                    Voltage Regulator 1 Model Number:
                    7805C
                    NLEV237
                    Voltage Regulator 2 Model Number:
                    BA033
                    26 96
                    Voltage Regulator 3 Model Number:
                    26AJ
                    LBBB
                    I could hardly see them as they are really small
                      You mean bigger capacitance 50v10uf 50v 47 uf 25v 1 uf 10uf 47uf
                      would be ok what have you got?
                        i do have these:
                        50v 47uF
                        25v 220uF
                        16v 470uF
                        25V 470uF
                        16V 1000uF
                          7805C
                          NLEV237
                          BA033
                          26 96
                          26AJ
                          LBBB
                          Ok First two are Voltage Regulators 7805 is 5v and bao33 is 3.3
                          I cant find the last one - check again with magnifying glass? Try cleaning it.
                          Test the first two
                          https://www.badcaps.net/forum/showthread.php?p=261329
                            i do have these:
                            50v 47uF
                            25v 220uF
                            16v 470uF
                            25V 470uF
                            16V 1000uF
                            Try the 50v 47uf - ok for test purposes
                              will do and post back
                                sorry for the late reply but was a bit busy...
                                I changed the cap and done the tests.
                                Voltage regulator BAO333 Test:
                                Pin 1 -> 0.01
                                Pin 2 -> 0.00
                                Pin 3 -> 0.01
                                Voltage regulator 7805C Test:
                                Pin 1 -> 0.01
                                Pin 2 -> 0.00
                                Pin 3 -> 0.01
                                Voltage regulator 26AJ Test:
                                Pin 1 -> 0.01
                                Pin 2 -> 0.01
                                Pin 3 -> 0.01
                                Pin 4 -> 0.01
                                Note: That I did check it with a magnifying glass and it was correct.
                                  That test is with it all connected and switched on and meter on VDC20?
                                    Pin 1 -> 0.01
                                    Pin 2 -> 0.01
                                    Pin 3 -> 0.01
                                    Pin 4 -> 0.01
                                    Pin 5 -> 0.01
                                    Pin 6 -> 0.00
                                    Pin 7 -> 2.2
                                    Pin 8 -> 2.4
                                    Pin 9 -> 2.5
                                    Pin 10 -> 2.8
                                    Pin 11 -> 2.9
                                    Pin 12 -> 2.5
                                    Hmm I think you have measured the wrong connector It only has 7 pins.
                                    see pic in post12
                                      Ok so I tested the connectors from the back of the board as I didn't manage to remove the connector.
                                      POWER ON, VDC200:
                                      Pin 1 -> 0.01
                                      Pin 2 -> 0.02
                                      Pin 3 -> 0.02
                                      Pin 4 -> 0.01
                                      Pin 5 -> 0.02
                                      Pin 6 -> 0.01
                                      Pin 7 -> 0.02
                                      POWER ON, VDC20:
                                      Pin 1 -> 2.76
                                      Pin 2 -> 3.9
                                      Pin 3 -> 3.46
                                      Pin 4 -> 3.58
                                      Pin 5 -> 4.41
                                      Pin 6 -> 4.15
                                      Pin 7 -> 2.89
                                      Please note that these are not still readings, they go up and down but this I noted the highest reading
                                        The tests were with meter on VDC200.
                                        Here are the tests with the meter VDC20:
                                        Pin 1 -> 0.77
                                        Pin 2 -> 0.00
                                        Pin 3 -> 0.30
                                        Pin 1 -> 0.81
                                        Pin 2 -> 0.81
                                        Pin 3 -> 0.81
                                        Pin 1 -> 0.53
                                        Pin 2 -> 0.36
                                        Pin 3 -> 0.43
                                        Pin 4 -> 0.28
                                          Here is an interesting thread - your Fet whilst not yellowed has a lot of glue on it - clean it off remove test and replace. See also the hairdryer trick - warm those 6 capxon caps
                                          and A) see if it comes on and B) retest the voltages. Next would be assume the caps are bad and replace. This is often the first thing to do wwith Capxon.
                                          https://www.badcaps.net/forum/showth...ghlight=1504FP
