Re: Proview PL926Wbi - recapped, same shut off issue
Ok good. You've narrowed it down to the ccfl. A place a lot of people out here recommend is CCFL Warehouse http://www.ccflwarehouse.com/
Hopefully its just a bad wire connection. Then you won't have to buy anything.
You'll need to strip it down to just the LCD panel. Then the outside edge pieces unlock and pry loose. Sometimes little screws have to come out in places. Be very careful with the board that connects to the plastic that goes inside the lcd screen.
You'll pry off a plastic piece around the edge (normally) and the lcd screen will be loose. Don't let it drop out. Then you'll get to some plastic sheets (diffuser sheets). Make sure those stay in the exact same order for reassembly. Then to the thick plastic plexiglass. The ccfls will be on the top and bottom. You may have to pull it out a little to release the bulbs.
Then you need to pry the end cap off the bad bulbs. Check for broken wires here. It might just be a bad soldering connection. If the bulb(s) are cracked or bad you'll have to order some new one(s). You'll need to measure the length and the diameter of the ccfl and put that in your order from ccfl warehouse. http://www.ccflwarehouse.com/tutorials.html
You can also call them and talk to them and maybe they can help with the measurements.
Just follow those tutorials I just posted. Then you put it all back together again carefully.
You want to perform this in a dust free room with no pet hair also. Anything that could stick to the plastic diffuser sheets.
The best thing is to go slow. Take your time. Good luck grasshopper.
Originally posted by Wyld_Goose
View Post
