BenQ FP71G
    BenQ FP71G
    Hello everyone,I have monitor BenQ FP71G and when turn on,somethimes works good without turning off,but when I do something(surfing the net or play the games) it's suddenly turns of.
    The most interesting part is when I take out the Cover from behind it's stays on and I can do everything(surfing,playing the games) it does not turn off.I checked if it's maybe something pressed the panel but it's seems good.
    I checked the caps,it seems that there are OK not inflated or burned or something else.
    Please if anyone can help me with it .
    Thanks a lot for answers.
    Re: BenQ FP71G
    Hi - when you say it goes off do you mean completely - what does the power led do?
    If it is just the backlight see if you can still see a very dark image on the screen perhaps shining a flashlight at an angle.
    Try also reducing the brightness and see if it stays on longer.
    Finally you should do this as a first step.
    https://www.badcaps.net/forum/showpo...2&postcount=21
    If soldering does not fix it then you will need to post pictures so we can look for problems..
      Re: BenQ FP71G
      Yes it's going cmpletely off,the power led stays on.
      Yes as you says,I can see a very dark image on the screen,almost nothing.
      Do you know what can be?
        Re: BenQ FP71G
        The CCFL lights aren't powering up. So it's either a bad inverter/power supply, or dead CCFL.
          Re: BenQ FP71G
          Please can you give me an picture of it and circle it please so I can find it.
          Thank you forwardly.
            Re: BenQ FP71G
            Superduty - if you read the post they do power up but then go out later.
            It is a known problem with this set.
              Re: BenQ FP71G
              We are going to need pictures of your boards and you will need to do the soldering as in the link I provided.
                Re: BenQ FP71G
                I got this well known tragedy which keeps blowing the 2SC5707 transistors. Or not exactly blowing, every time one gets slightly more open and than it stops working (2 seconds to black).
                May the foil capacitors be bad shorting the transistors?
                ADD// all of them are fine shich is strange. I have even tried a bruteforce by using two transistors in paralel So it seems problem realyl is somewhere else…0.22K 160 probably means 0,22uF 160V polyester caps, right?
                ADD2// Oh man, thanks for the Viewsonic VX924 threads Seems to indeed be them polyester caps. Replaced them with two 0,15uF 250V (closest I've found right now) and it seems to work. Will test it during the week, hopefully it will be OK and I can ship it to customer
