This unit works perfectly when it wants to come on. Once it comes on, will run forever. However, there are times it will not start. If I cycle power enough times, the unit will finally come on. Does not matter, remote or local on button, same result. Should I be looking at smps or main? I tried heating different sections of both boards..no difference. I have 12 volts and 5 volts..one pin reads 4.2 volts..very strange. Nothing labeled as far as voltagees or functions of the conductors. Pictures coming.
Element ELCFW329
Re: Element ELCFW329
With something like that, we always need the pin out name with the measurements on the PSU connector between it and the main board, while not working and while working. In your case I think you have 2 connectors we need measurements from. Look at SJ, they sell an EEPROM if your problem fits their description.
