I am unsure what is wrong with this unit but ... I will say the transformer seems awfully noisy. Symptoms are the power led blinks blue then shuts off I am curious as to what the cause is but I would be guessing it is likely a power supply related issue because the standby lights work I would say it would be something in the non standby circuit is not getting the proper voltage or something along that line as I said the transformer is louder then I would suspect it would be but the problem with this is it is labeled BCK02 and the company it appears is OQO that makes it and I can find zero information on this unit but I am willing to replace it on a hunch is this normally a high failure item or would there be no power at all and a blown fuse if it were faulty?
I guess I dunno much but am trying to learn and figured this broken item would be great to learn from... I will likely be ordering a good one with good boards so I could narrow it down to the power board or the main board. Everything is just based upon a hunch currently until I learn some more. But I really have the need to learn a bit more about these circuits.
I will include a picture of the PSU just for reference in case it helps.
