hi i just picked up a 204bw works fine on VGA but put it in DVI and it works fine for a minute or two then small pixals start flicking on parts of the display untell the screen goes black, then it comes back again and goes black again rinse and repeat. i suspect maybe caps, it looks to have been opened before, but since its only doing it on dvi and not vga its probably not the power supply i would think.
Samsung 204bw problems
Re: Samsung 204bw problems
ben using it all day at work on VGA been working fine with DVI it worked on my friends computer for 30 minutes before going on and completely off and then the long on the longer it took to come back, but since it works fine with VGA i wouldn't think its the power supply?My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
anywhere i can find a tear apart guide for one of these things.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
You lift up the front bezel at the top center then slowly and carefully work you way around with flat plastic or wooden tool but do not lift the bezel off completely. Put it face down on soft surface then snap back the back cover.
http://s807.photobucket.com/albums/y...msung%20204BW/Never stop learning
