ThinkVision 9417-H87 LCD black screen
    I have an IBM ThinkVision 9417-H87 LCD monitor that has a black screen. When powered up the LED turns green, but still nothing on the screen but blackness. Maybe a brighter black, if that's possible. Checked the power board and found fuse ok, but has 3 bad CapXcon caps. They are bulging and one has discharged brown liquid so I am pretty sure these are gone or on the way out. All others look fine. Will post pics soon, any suggestions?
    Re: ThinkVision 9417-H87 LCD black screen
    The video board looks fine. The caps on the power board are...
    3 - 820UF 25V (these are the only caps that look bad)
    2 - 1000UF 10V
    1 - 330UF 10V
    1 - 33UF 25V
    1 - 47UF 50V
    1 - 10UF 50V
    1 - 1000UF 450V or is it 100UF 450V (hard to tell)
      Capxon makes terrible quality caps. Thus, the non bloated ones are suspect due to guilt by association.
      See my standard reply regarding replacing capacitors at (regulars may skip)
      https://www.badcaps.net/forum/showpo...84&postcount=3
      --- begin sig file ---
      --- end sig file ---
        Thanks. Here are some pics of the boards.
          Looks to be a Samsung made board. The large 450V 100uf cap can be left alone as it rarely fails. The other 9 smaller caps should be replaced with something like Panasonic FR, FM or FC series low-esr caps.
