Below are pictures of 1 of the 2 boards from a mge / eaton evolution 1150va battery backup. The battery backup has no signs of life with fresh batteries. It died after a power failure discharged the batteries. / shows no signs of life, will not turn on. This is a high quality battery backup with avr / full sine wave output.
I'm trying to determine if there is a startup cap / whether it is c53 on the board, please help me with the photos below.
C53, C6 is 50v 10uf
C66, C22, C19, C2 are all 50v 47uf
C5, and C8 are 250v 22uf
c13, c65, and I believe but cant read c64 are 35v 1000uf
The negative on every cap is connected to the negative of the batteries most of the outer edge of board is all negative instead of case ground. There appears to be almost no case ground on this board. Negative on the battery would be 23-26v depending on battery charge. (4 x 6v sla batteries)
The power button logic / usb and what not are on a separate smaller board connected by a ribbon cable, but youd think the batteries probably should charge even if that board is not present, but this doesn't charge the batteries when plugged in.
C53, C6 is 50v 10uf
