Re: Non inverting Schmitt Trigger question
I think you are missing the point. That article is there to get you thinking about how other designers approach a similar problem. Or, if you find the ideal IC for your window control, most likely it will contain the drive transistors, so you won't have to worry about designing a bridge.
If you WANT to make everything from scratch, high or Low side is something you can decide later, based on decisions that you have NOT made yet. Choosing between an N or P transistor is the same...which one makes sense in your circuit? Current is current.
Rather than jumping to the schematic phase, define the operation with a block diagram and a logic chart so we know what you want to do. Then we can all offer our 2 cents worth about how to do it. Personally I would use one of the hundreds of analog control IC's for the motor drive.
Originally posted by Dannyx
View Post
