Part ID question
    Part ID question
    Ran into a part I don't know the OEM or type.
    Attached is a photo.
    Not the big orange caps, but the little ones near the center, that look like they were intended for through hole pc mount.
    This is part of a modulator for a Harris broadcast transmitter.
    Thanks in advance.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    Re: Part ID question
    film capacitors
      I see the Orange Drop and CDE silver mica caps, but not sure about these ones.
      Label is 4.7M or 47M 50V which is too small in value for film caps?
      It has 3 camel humps like maybe ferrite bead inside, square base. Hmmm.
        meter one.
          i think its polyester film capacitor
            films dont go bad as far as i know
              Pete,
              Apparently the prior maintainer of this transmitter went out of his way to screw this thing up. So most anything can happen.
              Jack Crow
              The Masso
              Mayor John Almafi
              MC Hawking
                film capacitors
                STJ and company,
                I passed on your answer and the others to Earl, one of my shop mates who is doing the actual work.
                Was able to find a vendor for the parts.
                Many thanks to all for the heads up.
                Jack Crow
                The Masso
                Mayor John Almafi
                MC Hawking
                  They look similar to these Sprague .047uf 50V Monolithic Ceramic Capacitors
                    I think they are Sprague disc capacitor, Z5U 50V 20% nothing special.
                    A 0.047uF one is 7CZ5U473X0050DC
