How can i locate the short on my Asus N73S
    Hello all..
    I have A asus N73s when i plug the power cord in it wil short...
    I want too know Where can i inject the voltage too trace where the defect component is
    I do have a dc power suply I can adjust the voltage and the amp also..
    Can sombody help me please!!!!
    Re: How can i locate the short on my Asus N73S
    Connect the power at the DC input to simulate the power supply, but first try to locate the schematics, likely you have a short at +B rail. (also check the pcb around the dc-jack positive pin if the jack is directly soldered to the board)
      I was searching for one on the internet the schematic.... I cant find it unless you pay 10 dollar for it do you know a Good website where i can find it? I do know for sure i have a short too ground.... Because when i set the multimeter in beepmode en i touch with my probes th dc jack + with ground its shorted... it beeps
        I guess you have the Asus N73SV.
          Yes it is a n73sv....can you maby help me with it.? Where should i inject the voltage and how much?
            First you need to determine where is the short, remove JP6001 and JP6002 and with a DMM check the resistance at both sides, maybe PD6000 (TVS diode got shorted), you need to isolate parts of the cirtuit to discover the short.
              Can u mark it for me on a picture wich 3 ? When i look at schematics i dont understand it... im handy at some things but not with schematics
                pic
                  Top left in your photo.
                    So i need put the power on those 2 solder joints?
                      No, he's suggesting you remove the solder at these two points which then reveal a break in the trace and you can test which side has the short with your multimeter.
                        Ok i will trie it... on wich mode should i set the multimeter im a newbie at this..
                          OHM range or diode testing will do the job.
                            I desolderd those 2 pads...wich area should i check? ... is there not a easy way like put amps on it and see if a component heats up? if so where should i solder the wires...
                              You need to locate which side has the short first before you start injecting voltage.
                              One probe on ground the other on the desoldered pads.
                                I tested it i marked it for you on the picture... on those 2 pads no value in the other 2 i see some... is that the right setting on the multimeter?
                                  Yes the correct setting. What's it show the other side of those pads ?
                                    On those other two the value wil climb up to 14.7k see the picture!
                                    What should do next? i tried two find a boardview file but overal i checkked u must pay for it... My schematic reading is bad!!!
                                      Check +5Vsb and +3Vsb
                                        Where two find those 2? Im really sorry... is sound really stupid... can u maby marked it for me?
