Hi, I took apart an old LG monitor and it has a ChungHwa CLAA150XG, the panel connects to the board by two 50 pin ribbon cables and the only LVDS to TTL converters I can find are for one 50 pin cable only, will it work with only one cable?
50+50 pin TTL lcd?
Re: 50+50 pin TTL lcd?
I see on CLAA150XG-01 50+30 pin on datasheet
http://www.datasheetspdf.com/datashe...A150XG-01.html
Can we see the pictures of the screen and the model number sticker showing the model of the LCD panel?
There should be a letter after the 01. is it 'F'?
Always provide FULL model number for less confusion.
Is this the one you have?
https://www.youtube.com/watch?v=sc0oPERZWy8
http://www.lcdparts.net/howto/instru...A150XG01F.aspx
http://cybersgeek.com/CLAA150XG01F
https://www.idallpart.com/15483107/claa150xg01f
You have to use the same panel as original for your monitor.
LG monitor model number?Last edited by budm; 07-22-2017, 07:14 PM.Never stop learning
Both connectors of the LCD has its own functions and signals requirement. So you need to find the spec sheet to get the correct pinout your LCD panel so you can find out if it can be driven by other driver board or not.
So right now you only have the LCD panel but not the whole monitor? What is the model number of the monitor?
So it is CLAA150XG '02J'.
So where did you get the 01 from?Last edited by budm; 07-23-2017, 10:23 PM.Never stop learning
