Ok, guys, I've been reading around on the forums, and decided to ask you guys what I should do.
I have recently taken up a hobby of fixing LCD monitors with Capacitor problems. Been buying them cheap and reselling them. I have been pretty successful so far.
But, I have run into an inverter that won't be fixed by replacing the caps.
The issue is that when "cold" the monitor will display for about 1 minute, then the back light cuts off. Then, if you turn it off and back on, it displays the Acer logo, then cuts off, then flashes the backlights 1 more time, then nothing.
This inverter has 3 - 25V 470 μf, 2 10v 1000μf, 1 - 10v 470μf, and 1 - 50v 22μf. I replaced them all with the exact voltage and μf rate Rubycon and Samxon caps that I got from Badcaps.
I resoldered the tranformer pins and also replaced the large 470v cap with a known good one. still no dice.
Any suggestions would be helpful. I have a multimeter and have also check the resistance on the fuse. It appears to be good to go.
What should I try next?
