I like the old Dell optiplex GX's but hate the unreliability due to the bad caps issue. Are any of the more recent (but not newest) immune to this problem? Seems like they would have gotten a handle on it by now....
Any Dells not notorious for bad caps?
Re: Any Dells not notorious for bad caps?
You can't even say you get what you pay for with Dell.... The Dimension is the low-end, Optiplex is the middle of the road, Precision is the high-end workstation, and the XPS is supposed to be the top-end in the desktop performance world for Dell.....all of which i've had to replace caps on. Dell poweredge servers are the only exception I've seen to this, they're most all polymer. The only model that was the exception to this was teh sc400, saw quite a few of those with bad wet caps.....but that's been a long time ago, they were older P4 systems.
My only guess would be that Dell really really likes obvious planned obsolescence.....most don't repair their bad cap dells, they replace.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Originally posted by Topcat View PostYou can't even say you get what you pay for with Dell.... The Dimension is the low-end, Optiplex is the middle of the road, Precision is the high-end workstation, and the XPS is supposed to be the top-end in the desktop performance world for Dell.....all of which i've had to replace caps on. Dell poweredge servers are the only exception I've seen to this, they're most all polymer. The only model that was the exception to this was teh sc400, saw quite a few of those with bad wet caps.....but that's been a long time ago, they were older P4 systems.
My only guess would be that Dell really really likes obvious planned obsolescence.....most don't repair their bad cap dells, they replace.sigpic
(Insert witty quote here)
I guess I havent seen one of those.....but FWIW, I have an Inspiron 5100 that was given to me with a bad motherboard. The inside of that was all plastic... Bought a used motherboard off fleabay for 50 bucks, and I've used it since. That's been 5 years ago. it's a P4 2.6GHz 1gb RAM, and a 160gb ide hdd. Added a wireless adapter and it does what I need with power to spare. Not bad for a $50.00 laptop! Ohh, I did buy a couple batteries for it.....don't remember what those cost....but they weren't much.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
Originally posted by Topcat View Post^
I guess I havent seen one of those.....but FWIW, I have an Inspiron 5100 that was given to me with a bad motherboard. The inside of that was all plastic... Bought a used motherboard off fleabay for 50 bucks, and I've used it since. That's been 5 years ago. it's a P4 2.6GHz 1gb RAM, and a 160gb ide hdd. Added a wireless adapter and it does what I need with power to spare. Not bad for a $50.00 laptop! Ohh, I did buy a couple batteries for it.....don't remember what those cost....but they weren't much.sigpic
Originally posted by ratdude747 View Postinspirons are junk.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team Stats
I have a poweredge 1800 with some KGZ's around the PCI slots :/Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Topcat View PostTell that to the one I've been running since 2005....and it was used when I got it.... it's circa 2003 I think. It doesn't owe me nothin if it died tomorrow....but this thread was about bad caps in Dell's, which omits notebooks...so I think that concludes that portion of the discussion.
On topic, though, I haven't heard much in relation to bad caps on more recent Dell desktops, not even on another forum I frequently lurk.
Poweredge 1800 is from mid-2000s, isn't it?Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
I have two v2s and one v1.
I am still looking at these boards nearly every day.
What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
The toaster ovens [mini cases] will have trouble of one kind or other until they are 100% poly.
.Mann-Made Global Warming.
- Dr Seuss
better than most anyway.sigpic
I actually find GX260's usually pretty cool with mostly good caps, though they're limited as far as memory (ddr 266 only) and cpu (max 533 2.8ghz)Cap Datasheet Depot: http://www.paullinebarger.net/DS/
Originally posted by Uranium-235 View PostI actually find GX260's usually pretty cool with mostly good caps, though they're limited as far as memory (ddr 266 only) and cpu (max 533 2.8ghz)
We have lot's of these at work (the regular desktops, not the small boxes). Some of them have good caps, others have Chemicon KZG and Nichicon HM/HN with bad date codes, but not one has let us down (okay, 1 did let us down, but that was due to a bad PSU).
And yes, they are indeed limited. Still good enough for office work, though.
The Dimension 3000 is also good (I'm sitting on one right now). Most of these were built after the Nichicon HM/HN fiasco, and they also have some polys around the VRM.
Of course these are even more limited than the GX260 - no AGP slot, 2 memory slots, and the motherboard won't take 1GB memory sticks.
- Dr Seuss
Originally posted by PCBONEZ View PostSHH! - Don't tell the 64-bit guys. They'll have a hissy fit.
64 bit is better but 32 is not useless by any means.sigpic
Originally posted by ratdude747 View Postexeption to the rule is laptops, these latitudes are very well built... you can't beat an all magnesium frame.
On the subject of Dell, just in the final stages of configuring one of our new servers. Dell PowerEdge R810 4 6-core processors (that's 24 cores) and 64GB of RAM. Holy crap does this thing perform.
The boss needed a new Windows Sharepoint server for testing, so I installed Server 2008 R2 in a VM, took about 15 minutes including patches and reboots.
He was like "how the hell did you get that done so fast?"
I had forgotten to allocate enough RAM, so when he said it needed more, I said log off for a sec. I shut it down, configured 4GB and an extra CPU, and fired it up again. That took about 65 seconds. I think I'm gonna like this box.
Gonna load it up with Exchange 2010, Citrix Xenapp 6, probably move our corporate Linux server to it as well.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....
Originally posted by choffman41 View PostI like the old Dell optiplex GX's but hate the unreliability due to the bad caps issue. Are any of the more recent (but not newest) immune to this problem? Seems like they would have gotten a handle on it by now....
My second desktop (app testing, packaging) is still a 745, performs very well.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....
https://www.badcaps.net/forum/showth...t=Optiplex+745
https://www.badcaps.net/forum/showth...t=Optiplex+745Mann-Made Global Warming.
- Dr Seuss
Originally posted by smason View PostThe Optiplex 745 were a very solid performer.
We also have some Optiplex GX520's - basically the same thing as the 745, but with half the memory slots and no PCI-E. Probably some other things too, I didn't pay that much attention.
Unfortunately, some of the above are getting replaced with HP Compaq DC5000, and those have failing capacitors of all sorts all over the place (even Rubycons). Ugh.
I have seen bad caps on a couple of poweredge servers including 2600's 1800's 600's 700's and 800's. I would guess and say maybe only 3 or 4 boards with bad caps. Not bad when I have 350 of them in service....... Other then that I have around 200 gx270's and as they come back in i redo the caps on all of them and send them back into service after testing everything. I think every company is plagued with some issue or another but Dell I believe uses the lowest quality components.
