50+50 pin TTL lcd?
    50+50 pin TTL lcd?
    Hi, I took apart an old LG monitor and it has a ChungHwa CLAA150XG, the panel connects to the board by two 50 pin ribbon cables and the only LVDS to TTL converters I can find are for one 50 pin cable only, will it work with only one cable?
    Re: 50+50 pin TTL lcd?
    I've seen a CLAA150XG-08 on ebay that has only one of the connectors, is it safe to assume it will work with only one?
    Is the 50 pin connector the same on all 50 pin TTL screens?
      I see on CLAA150XG-01 50+30 pin on datasheet
      http://www.datasheetspdf.com/datashe...A150XG-01.html
        Mine is a CLAA150XG-01, datasheet says 45+30 pin, but my screen has 50+50, both connectors are the same.
          Can anyone help? I really need to know if I can use a VS-TY2662-V1 board to output to this screen but I had never seen a TTL screen before. Datasheet doesn't help one bit.
            Can we see the pictures of the screen and the model number sticker showing the model of the LCD panel?
            There should be a letter after the 01. is it 'F'?
            Always provide FULL model number for less confusion.
            Is this the one you have?
            https://www.youtube.com/watch?v=sc0oPERZWy8
            http://www.lcdparts.net/howto/instru...A150XG01F.aspx
            http://cybersgeek.com/CLAA150XG01F
            https://www.idallpart.com/15483107/claa150xg01f
            You have to use the same panel as original for your monitor.
            LG monitor model number?
              Here are the pictures of the screen. http://imgur.com/a/hoIHw
                I want to use it with a universal LCD controller with TTL output, such as a VS-TY2662-V1, but I'm confused about the pinout.
                Could it be that they have the same pinout and the second cable is there just for redundancy?
                  Both connectors of the LCD has its own functions and signals requirement. So you need to find the spec sheet to get the correct pinout your LCD panel so you can find out if it can be driven by other driver board or not.
                  So right now you only have the LCD panel but not the whole monitor? What is the model number of the monitor?
                  So it is CLAA150XG '02J'.
                  So where did you get the 01 from?
                    The monitor was a LG 566LM.
