42lg3000-za No Picture but got sound
    Re: 42lg3000-za No Picture but got sound
    master
    test1=0.00
    test2=0.00
    test3=0.00
    test4=0.00
    slave
    test5=0.00
    test6=0.00
    test7=0.00
    test8=0.00
    And the same results with probes in reverse order.
    Have not got to take the cover of t-con as yet, seems a bit tricky. will do tho
      can you post a pic of the t con and cover we may have some ideas on how they come off.
      was the readings taken with the meter set on 20kohms?
        ok got the cover of, cable a bit more harder
          yea meter was on 20k ohm
            Can you see the fuse on the tcon - small white 3A
            Think you have tested transformers incorrectly
            Put on 2000ohms (Not 20k) and put one probe on pin12 then the other probe onto each of the other 3 pins on that end in turn
              meter set to 2k
              Master
              Transformer T1
              test 1 = .000
              test 2 = .000
              test3 = .000
              Transformer T2
              test 1 = .000
              test 2 =-1 on left side
              test 3 = 1 on left side
              Slave
              transformer T200
              test 1 = .000
              test 2 = .000
              test 3 = .000
              tranformer T201
              test 1 = .000
                Yea fuse on T-con checks as ok
                  i have not tested this type of invertor tranformer myself before i was just going by toms post 65? so not sure but at least you have posted the readings so someone should be able to comfirm for us.
                    Im really thankful for you guys help, i know its still early, in the diagnostic stages.
                      I was hoping it wasnt.
                      Still dont think we have the correct test for the Transformers. They usually measure 400 -1500 ohms Some of them have one end of the secondary at one end and the other at the opposite end of the transformer. I have looked on line but cant find much on these transformers - but it is good I can read the part numbers in your pics.
                      The likelyhood of all secondaries being sorted or open is like winning the lottery.
                      Is there a problem with pics of the backs of the inverter boards
                        Theres nothing on the backs of inverters , sorry im not at the same place as the TV now.
                          Aint given up yet, im not at the same place as the tv, be greatful if someone can get me a close up of (vit71053.54 master) just yesday i had a real close look on mines aint sure but theres an area on my board that just dont seems right. Like someone tried soldering or them lil black rectangle bits missing.
                          I just want compare, my board with a good close up image.
                            Which area are you talking about - give the board part designations - like Qxxx.
                            Not all positions are populated - they are just put on the board at design stage in case of need. Its easy to not use a position but difficult to add one later.
                            We are unlikely to find a picture if you cant - now you see why we ask for good clear pictures?
                              selldoor you see the pix in post#86
                              If you look in the center of board, it looks like bits of solder all over the gaff.
                              I know whot you saying but this looks kinda unprofessional.
                                Post #6
                                "pin 1 is a blue wire should be 24v
                                pin 2 is grey 24v
                                pin 3 is grey 24v
                                pin 4 is grey 24v
                                pin 5 is grey 24v
                                Then the next 6 to 10 are GND
                                pin 11 =BR1
                                pin 12 =on/off
                                pin 13 =pwd dim
                                pin 14 =error"
                                So do you get 2.9VDC (as indicated in post11) at the pin 12,
                                Pin 14?
                                By the way, what is the P/N of the Inverter controller IC?
                                  Budm
                                  post #11
                                  pin 10 on/off meter reads 2.9
                                  pin 11 pwm dim meter reads 0
                                  pin 12 n.c meter reads 0
                                    Ones I have looked at are just the same
                                    Here is one example
                                    http://flattvparts.co.uk index.php?main_page=product_info&products_id=7884
                                    - google the board number and you can find others
                                      Please see the redlined test points with reference to the chassis ground.
                                        By the way, do you see this?
                                        http://www.ohmsupplies.co.uk/REPAIR-...T7105354-LG-42
                                          Oops: duplicate
