Have a Benq FP92E (Q9CS) inverter board 4H.L2T02.A00 that is missing c703, c704, c707, c708. Wondering if anyone knows what uF and Volts these need to be....Thanks..
Benq FP92E Capacitor specs Help!!
Re: Benq FP92E Capacitor specs Help!!
Originally posted by riverrat_67 View PostHave a Benq FP92E (Q9CS) inverter board 4H.L2T02.A00 that is missing c703, c704, c707, c708. Wondering if anyone knows what uF and Volts these need to be....Thanks..
Sometimes the same board is used in different products with a different "build".
And sometimes it is as simple as the board layout not being changed after the manufacturers discovered those extra bits allowed for by the designer aren't actually required. It's called the beancounter effect. "If it ain't needed, leave it out." and also "why change the board layout just because we are leaving bits OUT?".Friends don't let friends buy Samsung ....
No there not empty slot you can still see the solder left over on the back of the board and holes..
I found a schematic for a FP71e (i think that was the model) where a lot of the circuit components match up. Go buy that it looks like c703 and c704 are 470uf 35v and c707 and c708 are 1000uf 16v..
Going to give it a try tonight or tomorrow morning i'll post the results. Whats the worst that could happen it's not working right now...Thanks
Originally posted by riverrat_67 View PostNo there not empty slot you can still see the solder left over on the back of the board and holes..
Looks like they used the same values for a BenQ FP91G. For the FP91G,
C703-4 filter the voltage fed to the inverter cicuit. C707-8 provides filtering for the 5V.
HI,
I have a board 4H L2T02.A03 from a Benq T721 who don't work. On my board C708 and C707 are 1000uF 16V, C703 and C704 are 470uF 35V.
I want to replace the board. Do you know where i can find it ?
Merci !Last edited by Bilbao; 11-19-2010, 02:39 PM.
1) Post clear focused pictures of your particular boards AFTER reading
https://www.badcaps.net/forum/showthread.php?t=1868
2) Please do not post pictures inline as they slow down the loading of pages.
3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
4) Here is an example of the pictures we want.
https://www.badcaps.net/forum/showpo...94&postcount=1
5) Also, start a new thread with the pictures requested since you have a different monitor so we don't get confused.--- begin sig file ---
--- end sig file ---
Please, can someone tell, what type is IC601 on that board? It have been blow off because C605 have leak and start the damage of other components.
If you have the same board on hand, please can you send the type of ic direct to mail: md.maxx@kolumbus.fi too.
p.s sorry my bad english, im from Finland
Also i'm interesting if you know or have working ic or know where to buy it.Last edited by MdMaxx; 01-08-2011, 12:25 AM.
Monitor Benq Q7C5 with same "4H L2T02.A03" works fine but after a few minutes (not seconds) momnitor goes off.
You can put it back on and then after a little again switches off.
Tested 8 big capacitors (2x 1000uF/16V 2x 470uF and 2x 1000uF/10V), soldering it out and measured ESR and capacitance, both are ok.
Hard to find without schema.
Anybody idea's or schema?Last edited by hifihifi; 10-26-2012, 01:10 PM.
