Yeah I know, they are pretty simple little circuits. But this time I used a hunk of scrap breadboard, did the component layout myself, and added in a few twists to better suit my needs.
The first twist is that I used dual right angle connectors to plug the PCB directly into each side of my breadboards power buses. So I now have access to the original input voltage and the regulated voltage output. Plus they also make the PCB very steady. I also went ahead and added in a jumper block should I ever wish to disable the regulator and while I was at it added reverse protection diodes. Due to lack of space all I could fit on it were two 50v 100uf elctrolytics on the input and output, I also went ahead and put a .1uf mono cap right next to the input pin. I'm using a 510ohm resistor and 10k pot for voltage regulation. Its pretty sensitive and will allow me to go "all the way down" if I so desire.
I figure I will try and "reform" some new old stock caps and see if I can detect any changes in their ESR levels. I'm kinda sorta thinking that slowly raising the output voltage may not be the best way about waking them up from a deep slumber... I'm kinda leaning towards hooking them up at full rated power and limiting the current that they will be fed via resistors.
