Toshiba 40RV525R repair (schematics?)
    Re: Toshiba 40RV525R repair (schematics?)
    not sure what to do with the information, though willing to learn.
      Was really posting for dick_barton or one of the other guru's on the forum to look at
        +1
        The IC pinout does not match what is shown in the schematic that was attached for the power board.
        However with the black meter probe on the negative leg of C102 carefully measure the DC voltages on all the pins of U101 very carefully so that the probe does not slip.
        Attached is an IC (not yours) showing how the pin number are orientated.
          Need good clear high res straight shot pictures of the bottom side of the board.
            U101 Pin readouts
            1. 2.12
            2. 11.05
            3. .82
            4. 0
            5. .32
            6. .01
            7. .01
            8. 2.10
            9. .64
            10. 0
            11. .37
            12. 0
            13. 0
            14. 131
            15. 131
            16. 131
            17. 0
            18. 0
            charging phone now pics to follow
              With the set powered off can you check the resistance between
              Pins 14 & 15 =
              Pins 14 & 16 =
              Pins 15 & 16 =
                Pins 14 & 15 = 445
                Pins 14 & 16 = 495
                Pins 15 & 16 = 51
                see above
                  Sorry but ohms or Kohms?
                    meter set at 2000K
                        Those resistance appear to be OK. Without a schematic for this power supply I'm stuck.
                        The supply voltage to the IC appears to be within spec at 11.5V but I am surprised that the high voltage supply to Pin 14 is only 131V and I would have thought it would be 332V as per post #16
                          I guess I have reached the end since I can't seem to locate any schematics for the PS.
                          Thank you all anyway. This wasn't so much a need for a television but more a desire to learn.
                          I sincerely appreciate your willingness to share your knowledge and skills developed through study and over time.
                            Hold fire since there are many other members who may well be able to assist you. Even though I'm out of ideas it does not mean that they are.
                              If you want to learn I would be checking all smd components around the controller as I believe one of those may be your problem.
                                wouldn't know where to start
                                please accept my apologies and ignorance
                                  Pretty much check all components with multimeter. Ones marked R are resistors c capacitors, D diodes. Charts on internet to tell you how to read resistor codes. If you really want to learn.
                                    Is it possible to test diodes or capacitors without removing from circuit?
                                      Depends if you get a good reading there ok. If you get a bad reading then you need to remove and check them out of circuit. There are lots of youtube videos on checking components.
                                        If anyone has this TV before you do anything test the fuses on the inverter board! This TV is known to blown fuses on the inverter board. But also this could be a sign the inverter board is bad. If you replace the fuse and it blows again then most likely the inverter boards needs to be repaired. Look at the underside for burn marks and that may tell you which part has failed. I just fix this TV by replacing the inverter board, good thing I had one. I first tried replacing the fuse but it blew the instant I plugged the TV in. So now I am going to try and repair the inverter board since the cheapest one I can find on eBay is $80.00
                                          I found IC's Q310, Q311, & Q312 to be bad on my inverter board. Marking on the IC's is ( 4614 BD9N4T ) Aparently the Brand name is AO. So I think the correct part number is AO4614. I just bought some for $0.17 each on Aliexpress, that is way less than $80.00
