pls can someone help me.i have acer aspire 5253, the problem is that the system charges to 100% but immediately i unplug the adapter, it will go off. i have bought a new battery thinking that it was the problem but to no avail. pls help me out.
help
Re: help
I moved this to laptops.
I'm going to take a shot in the dark and say motherboard, but let some of these laptop gurus here give it a goCap Datasheet Depot: http://www.paullinebarger.net/DS/
Re: help
In most laptops no matter brand there is usually 2 sets of mosfets. One set will be by charge port or nearby the other set will be by battery charge pins , you will need to check them. Without even looking at schematic that is best bet, Some designs only use one set of fets. Symptoms are if one of the side by side fet goes bad it will run off charger but not charge battery, if other goes out it will run off battery but not charger and if they have a bad battery this can be a bummer because laptop will seem totally dead. a pain to isolate unless you check fets.
Re: help
Yes i agree real easy to check with out schematic each circuit has a buck controller one large square coil and two 8 leg mosfets so locate them near the battery connector with no power to board at all put your meter on diode mode you need to check the four inner legs from left to right reversing your probes one way you should get a reading from 100 to 400 the other nothing if good .
Techman1025
