Dear friends,
my ASUS VH222H 21 inch monitor suddenly is no longer running, the power button does not have effect and the blu pwr led remains off.
I completely disassembled the monitor to do a visual inspection.
Unfortunately, even using a magnifying glass, I have not been able to identify any damaged capacitor, no component visibly burned or damaged runways.
I did a test just by connecting the high voltage to the LCD panel, leaving disconnect the LVDS cable, and surprisingly the monitor turns on and the display lights up. Of course, no image appears.
If I connect the LVDS cable, the monitor remains black and not even turn on.
Monday morning I would like to take some high resolution photos of the main board and power board to post here, if I had missed some details you might definitely help me.
In the meantime, I would argue with you experts on what could be the cause of such a failure.
For example, since the display lights up, is it fair to exclude a priori a problem on the inverter / high voltage circuit?
thanks
max
thanks
max
