Re: Samsung 231T, recapped, no power, no lights
I am assuming ref to a 213T is a typo - you can edit it if your quick
Your right it doesnt have the fuse detail however if you look at the 'silver' ends of the main fuse it has the details on it. Have you tested the fuses? if they are good you dont actually need the detail
Its always better if we can see your boards as we may spot
problems
The suggestion to replace caps after the mosfets is because the mosfets may have failed because as caps fail they put pressure on other components eg mosfets
so if you have replaced mosfets it makes sense to replace the caps that may have contributed to their demise.
problems
