HP L1740 Monitor doesn't light up
    Re: HP L1740 Monitor doesn't light up
    Originally posted by Mike Toole View Post
    Anyone up for helping? Where should I start? Or should I just replace all caps? Is there a visual guide for soldering/replacing caps?
    Welcome. For future posts, do not post pictures inline. Instead, use the manage attachments feature.
    1) When you push the power button, does the power LED go green?
    2) Do you see the screen flash on quickly?
    3) If you shine a flashlight to the LCD, do you see a display?
    4) Do you have a multimeter? If yes, Benq boards are notarious for certain problems (see post #4).
    --- begin sig file ---
    --- end sig file ---
      Yes to each of those questions; I've done my homework. The multimeter is at work right now, but yeah, I've got one.
      Sorry about the big pic, I thought the autoscale built into the forum was good enough - won't happen again
        Check the transistors to see if they are shorted, and resolder all the inverter transformers pins. If the screen flashed briefly, the picofuse should be good, but doublecheck with a multimeter.
        The autosize function helps, but each time we visit this page, it has to be loaded over and over again. This slows down the loading of pages.
