I just bought a Blue Ring Tester Testing fly back transformer need help with results
    Here are the results of the test
    Pin 1 and Pin 9 <.... I get 3 green lights
    Pin 2 and Pin 8 <.... I get 1 green light
    Pin 3 and Pin 6 <.... I get 2 orange lights
    Pin 4 and Pin 5 <.... I get 2 orange lights
    Pin 1 to Pin 2
    Pin 1 to Pin 8
    Pin 1 to Pin 10 <.... I get no LED lights
    Pin 10 pin 11 pin 12 pin 13 <.... I have N/C
    If there are any other pins that I need to check to know if this part is good or not Please let me know thanks
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: I just bought a Blue Ring Tester Testing fly back transformer need help with resu
    Also
    Pin 9 to 10 <.... I get 3 green LEDs lights
    Pin 7 to 9 <....I get 3 green LEDs lights
    Pin 2 to 9 <.... I get 2 green LEDs lights
    Pin 2 to 10 <.... I get 1 orange LED light
    All other pin to pin I get two red LEDs lights
    9 PC LCD Monitor
    1 Dell Mother Board
      Check these two sites.
      https://cdn.badcaps-static.com/pdfs/...f184d5a6d3.pdf This is an in-depth article.
      http://www.anatekcorp.com/ They have a discussion Forum you might check.
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
