Yamaha HTR-5920 cracked schottky diode
    So I was replacing some bad caps on this receivers main amp and a glass schottky was inside the goop by one cap and cracked when I removed it. I already got some good idea from another member but I don't know if there is anything else I need to know. Here a direct link to posts and pictures
    https://www.badcaps.net/forum/showth...24&page=38#756
    if anyone has a schematic to this board, that would be fantastic
    thanks
    Re: Yamaha HTR-5920 cracked schottky diode
    found service manual. D938. References Q654. Also had a diode list but not sure which one it is.
    now i'm not sure its a schottky, maybe Zeiner
      1SS133
      it is written next to it on schematic .
      http://uk.farnell.com/rohm/1ss133t-7...rfnonsku=false
        I thought that area would be text searchable, shows what I know. Thanks for the info, you're a life saver
        ugh shit, I am not finding a replacement at mouser my closest supply. How much margin is there for error on this one? can I just surpass the maximum surges to the nearest high value? voltage too?
          1N4148 or something like it should work .
            I usually keep about 50 1N4148's around the house.
            sigpicThe Sky Is Falling
              its been answered before but I would like a second opinion, do you think the forward voltage difference of 200mV should be ok?
              also, do you think the stuff covering the diode was there to prevent the cap from heating up too much? I mean, it has a 175C tolerance, putting it next to a 105C cap, was it for this purpose.
              funny ive dealt so much with caps on mboards and tvs but when it comes to pretty much every other component i'm pretty much in the dark (except maybe resistors)
                Should be fine. That's such a small difference.
                  well I got them (diode, all 4 caps)
                  and, nope. The original problem was just a 60hz hum
                  now the initial power relay clicks, and as soon as the main amp relay clicks it turns off
                    are you running it direct on mains power ? not that it should do this even on limited power .
                    any speaker loads ? if so try without .
                      I'm...not sure what you're talking about.
                      speakers, yeah, I disconnected them , one at a time to see if it made any difference, nope
                        try both disconnected
                          So the main power relay RY91 drops out when the speaker relays (RY61~64) comes on?
                            it sounds that way
                              video (turn your sound up, kind of soft)
                                It powers up, after a delay, relay clicks and it powers off?
                                The MCU has made an executive decision, lol. If this is what is happening, I'll guess... two things.
                                The MCU has a mega power supply monitoring line PROTE_PS pin 5 BN82 to CN96. It's a summation of a bunch of PSU voltages. This signal gets renamed PRV and is a monitor for +5V, +12V, -12V and the amp's rails +50V, -50V.
                                I estimate that line should be 2.5VDC if all PSU rails are OK. If you can watch it with a multimeter. Guessing the MCU turns things off if there is trouble seen there.
                                It might be nightmare in the muting circuit you were in, with D938 (by IC98).
                                Did you have a failed STK402? Maybe unmuting the power amps causes one channel to have a DC shift and trip the protect line at Q559/Q558.
                                I don't know what this receiver does if a power amp problem trips PROTECT.
                                Most stay on and display PROT or something, instead of powering down.
                                  normally it clicks once the second you turn the power button. Display turns on and displays the volume or input for a second, and the second click turns on the speakers.
                                  I don't think the second relay is clicking on, the sound is the first relay clicking on and off
                                  I don't think my relays are failed. The unit was working just fine with the exception of 60hz buzz that I were believed from the bad caps on the main vrm (C960, C933(which wasn't bloated, but I replaced it just in case)). And two more next to them
                                    If something works worse after I replace parts, I check my soldering, connectors etc. in case I did something "extra"
                                    I would measure the power supply voltages and see if they are good, and then the 6 power amp output voltages to check if a channel has DC offset and it's in protect mode. R564-R570 are one place to measure voltages.
                                      Already checked it. Indeed I did break some traces right around many of the joints, but I scraped the insulation off the trace and flowed the solder to the trace. I then check the nearby joints with the meter to make sure its connecting, all seem fine.
                                        I've never owned a Yamaha, but I have read a lot of people griping about their crappy soldering. You probably flexed the board and made the bad solder worse. You could just reflow everything you can around the relays.
