Hello klangsotan.. do you updates on what happen to your Sony vaio model pcg 31311 w no power? mine still dead too no power, no light.. anyone can help me?
It was no power (Sony Pcg 31311m )3v and 5v were not generating .then I
checked U65 in put and dc jack connector wow no voltage.I thought dc jack is
faulty. but its not, once i connect dc jack to the connector no voltage. once i
remove it voltage present at the end of connector. after that I checked dc jack
to ground component and those were fine.finally remove the board connector
and dc jack connectors soldered on board.wow works great!!!mysterious thing
is no problem with the removed connector.if you have come across with this
situation let us know
I have this pcg-31311w sony no power, I already check and 3 volts and 5 volts are not present. Can anyone help me? I also need the schematic for AMD board type. I think "atsio" uploaded schematic for Intel ones... please....
