SAMSUNG LE40C530F1W no picture with sound
    Hello there i am having a problem with my samsung tv
    The problem is the same with this one
    https://www.badcaps.net/forum/showth...ht=bn44-00340b
    I think i found the problem but i dont know how to fix it
    The inverter circuits of this board does not run off the 24V power supply, it runs off the PFC Voltage booster which is >360VDC, the main inverter is on the power supply board, the board connected to the lamp is the balancer board.
    You need to find out if you do have >360VDC on the fuse (tested good per your post) in the middle of the board, use the negative leg of the main filter cap as the ground ref. point.
    I did the test budm said i am counting only 305v at the middle fuse
    AC line voltage at greece is 230V
    How can i fix this ?
    Thank you
    Re: SAMSUNG LE40C530F1W no picture with sound
    If your line AC Voltage is 230 VDC, then the DCV between the two legs of the main filter cap should be around 330VDC when TV is in stand by mode, and when the TV is turned on then the DCV should jump up to be > 360 VDC (usually will be closed to 400 VDC).
    305 VDC does not look right at all. You should verify that your meter is OK.
      thank you for your reply i will try to find a new meter and try again !
        i tried again with a new meter and it looks wierd again!
        standby i have 322v and when i turn on the tv it goes a little bit down to 317v
          any ideas ?
            322V is pretty close to 325vdc (AC @230vac) What is the measured AC feeding the TV? Multiply that by 1.414 to get what you should have between the two legs of the main filter caps.
            'Samsung LE40C530; turned on, flickered, now no backlight (but picture/sound work).' You are saying that you have the problem as OP? You have no backlights but you do have sound just like OP then?
            Check Diodes DP801, 805.
            We need to get that boosted Voltage first, you do have have standby Voltage and all the commands signals from the main board, right?
              with everything connected to the psu and the tv turn on i am having these measurments
              pin1-3-5-15-17=12,7v
              pin7-9=0v
              pin11-13=5,2v
              pin2=0v
              pin4=4,4v
              pin6=2,06v
              pin8=1,70v
              pin10=0v
              pin12=0v
              pin14=5,2v
              pin16=5,2v
              pin18=1,5v
              Yes problem is the same i have sound and the backlights does not open but i can see the picture moving with a flushlight.
              both diodes was ok
                should i order a new psu or could be something else ?
                  At this point you do need new power supply/inverter combo board since the PFC Voltage booster is not working right now.
                    Thank you dudm!
                    One last question plz my psu is the BN44-00340B REV 1.4 i have found the same board but REV 1.2 is this ok or i sould find exactly the same?
                      1.2 is an older revision, I would get the same revision or newer revision. They may have released new revision to fix what they found on the old revision.
                        I have a very similar problem with the same model. In my case it would power on but backlight does not come on at all. I measure the voltage on the main filter caps with the TV powered on and logic bord connected and i get like 305 Volts like takisp.
                        I also found a bad zener. The ZDP804
                          After removing and checking the ZDP804 it appears to be ok. Also i replaced the PFC chip and nothing changed.
                            We need to verify if you do have the VCC to run the PFC IC or not first.
                            BTW: your power supply board is BN44-00340B?
                              I think that is the psu. I will confirm it and get back here.
                              The vcc i measure between the resistor pr823 and GND or chasis ?
                              What voltage should i expect ?
                                You are working in the primary side of the circuit so the Ground reference for the primary side of the circuit will be the negative leg of the main filter cap (the big electrolytics cap with 450VDC rating.
                                  Got it... Any idea what voltage should i be expecting ?
                                    15~18VDC range is typical, best to get the P/N of the PFC IC to look up the spec. sheet.
