Powerleap iP3T v2.0 Slot 1 Adapter
    Have acquired two of these.
    They both have crap caps, e.g. 4 of NKCON 10V 2200uF 8mm and
    1 of NKCON 16V 1500uF 8mm. The adapter is run from a molex FDD connector.
    I would like to replace these with something better.
    However, it is critical these replacements are 8mm dia. to fit correctly
    I cannot find any Pana FC or FM in 8mm for these values.
    What other options are available to me given the dia. constraint.
    I guess at a stretch, 6.3V 2200uF 8mm might be available for +5.0V.
    Also, is it possible to run these adapters with Tualatin PIII-S?
    Any suggestions and advice is welcomed.
    Re: Powerleap iP3T v2.0 Slot 1 Adapter
    Yes, if the BIOS support Coppermine processors. However to benefit fully, the motherboard also need to support 133 MHz FSB.
    Be a mensch
      Appears Chemicon KZJ 6.3V 2200uF at 8mm diameter would fit the bill for the +5.0V rail on this adapter
      Problem is getting a reputable 16.0v 1500uF at 8mm
      Suggestions?
