I have a Emerson LC320EM9B the standby light is red then I hit the power button the power light flashes 11 times then stays on green and I see the words "Digital Television" come on the screen for a second then goes out and the green power light goes out and the red standby light comes back on. I took the back off and no obvious bad caps I can see no burning or hot places I see so not sure where to check next. Ideas?? I uploaded what the boards look like.
Emerson LC320EM9B on then off
Re: Emerson LC320EM9B on then off
i don't know if it is the same problem but this was a thread i created for a sylvania 37" but you might be having the same problem because it is pretty much the same setup except mine has 7 inverters not 5 check it out and post if that was it. if not someone here could help troubleshoot it. but it is always good of you to take pics of the back of your tv with the cover off and single pics of all the boards so we can maybe see something you may have missed.
https://www.badcaps.net/forum/showth...light=sylvaniaLast edited by philliesfan30m; 02-06-2014, 07:59 PM.
it might also have a bad inverter. causing it to go into protect mode now that i think about it. take the board off and measure the resistance of the inverters. take a pic of the bottom of the board. maybe i bad inverter is causing it to go into protect mode. you should be able to tell by testing them and seeing if they are all the same then they are probably good but if 1 varies a lot then thats probably your problem.
