Hi everyone, i want to ask you about my Viewsonic lcd monitor, when i power it on backlights blinks one or two times and after that screen remains black. When I take out the mainboard and the power supply i havenĀ“t not notice any puffed capacitor, but the power supply was noisy. I paid attention and figured out a transistor overheated next to 470mF caps (see picture). The problem was i cannot identify what kind of transistor it's because i cannot read the identification code...I attached a pic of the power supply and transistor to see if someone can help me! Thanks.
Viewsonic VE710b Power on black screen
Re: Viewsonic VE710b Power on black screen
Hi you perhaps need to read this: start at post 19
Your component is a diode from the board description
In the above it tells how to test it with a multimeter.Please upload pictures using attachment function when ask for help on the repair
Originally posted by Guti904 View PostThe board code is slv03150450 and the diode is marked in the attached pic of the first post.
Other members might be able to work out what is needed from the surrounding circuit - please post a picture of the back of the board as well.
Best to test it first to save us all looking for a replacement.
Try and clean it by rubbing with isopropyl alcohol- even some of the letters/numbers would help.Please upload pictures using attachment function when ask for help on the repair
I tried to read the diode (or transistor) code and this is what i've read:
STM DGH10 DCT
75ADG VW or (7SADG VW)
606
the first line is the most unreadable, the other two lines seems to say that.
The input of the power supply is 100-240V and ouput: 12V 1.25ALast edited by Guti904; 06-22-2012, 11:54 AM.
Hi - I think it may have been ST ( That is the manufacturer ) M60H100CT.
Which might make it close to
http://www.digikey.com/product-detail/en/STPS60H100CT
I will keep looking - wait and see what anyone else discovers
- have you tested it yet?
EDIT unfortunately it could equally have been STM 40H100CT
Which for some reason or other is now 41!!!?
http://www.digikey.com/scripts/dksea...s=STPS41H100CT
Need some guidance as what would happen if you used a 60 as against a 40Last edited by selldoor; 06-22-2012, 01:21 PM.Please upload pictures using attachment function when ask for help on the repair
Make sure the replacement is Isolated Tab TO-220 since the Common Cathodes are tied to the center pin, non-isolated tab the tab will be tied to the center pin, since the heat sink is grounded, you will ending up short out the Diode if you do not use the Isolated tab TO-220.
You should verify by measuring the resistance between the center pin and the mounting tab. If the heat sink is not tied to ground then you will be OK.Last edited by budm; 06-22-2012, 01:54 PM.Never stop learning
While you are testing I notice the board has been hot under
the inverter transformers so perhaps you can test the transformers. No power to the board, meter on 2000 ohms. I will add a pic showing what I think are the secondaries.
Measure S1>S2 and S3>S4 and post the results.
Do you have any spare working lcd bulbs or another panel (broken or laptop screen might do) to substitute for the current bulbs.Please upload pictures using attachment function when ask for help on the repair
Originally posted by budm View PostMake sure the replacement is Isolated Tab TO-220 since the Common Cathodes are tied to the center pin, non-isolated tab the tab will be tied to the center pin, since the heat sink is grounded, you will ending up short out the Diode if you do not use the Isolated tab TO-220.
Originally posted by selldoor View PostWhile you are testing I notice the board has been hot under
So it is not Isolated tab, is the resistance between the heat sink and the negative leg of the electrolytic caps (470uF) next to it shows open circuits? Just want to make sure the heat sink is not grounded.Never stop learning
Originally posted by budm View PostSo it is not Isolated tab, is the resistance between the heat sink and the negative leg of the electrolytic caps (470uF) next to it shows open circuits? Just want to make sure the heat sink is not grounded.
Multimeter in 2K Ohms
(black probe - red probe)
1-2: infinite resistance
2-1: 5.45 KOhms
1-3: infinite resistance
2-3: infinite resistance
3-1: infinite resistance
3-2: infinite resistance
2-4: continuity (0 Ohm)
4-2: continuity (0 Ohm)
3-4: infinite resistance
4-3: 5.57 KOhmLast edited by Guti904; 06-22-2012, 04:08 PM.
Perform a diode test for verification.
1) Set your multimeter to diode test.
2) Put your red probe on pin 1, black on pin 2. Report reading.
3) Put your red probe on pin 2, black on pin 1. Report reading.
4) Put your red probe on pin 3, black on pin 2. Report reading.
5) Put your red probe on pin 2, black on pin 3. Report reading.--- begin sig file ---
--- end sig file ---
Originally posted by Guti904 View PostThe resistance between S1 and S2 is about 160KOhms and between S3 and S4 is also 160KOhms...
There are mutiple VE710b versions.the monitor should also have a model number on,and they are all different as far as I can tell.As different manufacturers can use different components, different layouts and circuits to obtain the same inputs and outputs,anything goes.So unless you got the above tfmr details from exactly the same board as this unit has then that is probably the difference
