Hey guys,
So I have a Vizio E320-B0 tv and after not using it for awhile I realized that it would not work properly. I plugged it in and it wouldnt turn on, so I just went on with something else and tried to turn it on about 5 minutes later and it came on. It was on for about 45 seconds and then shut off. I then left it as it was overnight and tried the next morning and it worked. I had a few days of it working and then turned it off and then it wouldnt turn back on. When I say that it would not turn on, I mean the little light on the edge of the tv would not even come on, not just the screen. So with the power light not coming on, I figured it would be the power supply as I have had to replace a few of those before on other tvs. I ordered a power supply from the internet and installed it....still no luck. I am wondering if maybe the new power supply is bad as well? The caps on both the original PS and the one that I just purchased look fine (no explosions) and no contacts on the board anywhere are burnt.
Info:
TV Model: E320-B0
Power Supply: 0500-0614-0400
Through research, I have seen that even though the Model Number of the tv should be definitive, there seem to be a few different E320-B0 models that some use different power supply numbers and main boards and so I made sure to get a Power supply with the exact number and appearance. The only difference in the two that I have my hands on right now are cap colors which could be due to the manufactures of that batch.
Any help would be appreciated and I am continuing research after I submit this.
Thanks Guys!
Info:
TV Model: E320-B0
Thanks Guys!
