Macbook A1342 (820-2883-A) bios dump
    hello guys
    someone can share this bios dump A1342 (820-2883-A)
    thanks
    Re: Macbook A1342 (820-2883-A)
    it is hard, if not impossible to mach efi bios on mac
    if you are removing password, its easier to read bios and discard password... pm me if you need help or post dump here
    i found few dumps here, you can try, but ALWAYS BACKUP your org bios
    Code:
    http://notebook1.ru/forma1/viewtopic.php?f=352&t=49555&hilit=a1342
    Im Back... sort of...
      thanks already try bios from this link but unsuccessful
      yes i am trying to remove password
        I'm not sure if this will do for you but give it a try.
        Remove one out of two RAM or add one if you have only one just to change the amount.
        Boot and make NVRAM reset by holding 'command', 'option', 'P' and 'R' all together.
          I have one at home, but can you tell me the EMC # ?
            upload yours if you want to help . what do you mean by EMC????
              Of course, I will try to help because we are supposed to help each other. that is the purpose of this forum
              Read this
              http://www.everymac.com/mac-identifi...ification.html
                thanks for help but yours is 820-2567 mine is 820-2883-A.
                  Oh..sorry about that, upload your original bios first for learning purpose, who knows we can bypass it
                    @dycc have you solved this?
                    would you be so kind to post your dump here pls, or send me a pm?
                      here mine
                        Sorry but i follow your link and i don't find $SVS in my dump .
                        sorry again for late reply.
                          many firmwares can be found here if you know EMC code
                          Code:
                          https://ghostlyhaks.com/downloads/2014-07-25-06-43-32/efi-firmware
                          this is an older version, don't have $SVS trick avilable
                          or try this dump
                            will try it . EMC=2350
                              unfortunately none of them work .
                                Sorry guys the original bios is working well . it was a problem with hard drive . tanks anyway
                                  Glad to hear that sir, maybe that's way no $SVS in your dump
                                    perhaps i have to set password and check if $svs trick is available
                                    thanks degutji and ala_borbe
