I have an IBM 6734-ABO which is not working.
Problem description:
I power up the monitor and green led comes on but there is no image on the screen.
What i have done thus far:
1-Shined flashlight on screen and i can see a faint image on the screen.
2-Measured voltages at connector (see enclosed pic of connector):
Pin1=>17v
Pin2=>17V
Pin3=>0.006V
Pin4=>0.006V
Pin5=>0.006V
Pin6=>5.11V
Pin7=>5.11V
Pin8=>0.038V
Pin9=>4.6V
Note: According to the writing near the connector the 17V reading should be 13V. Is this a problem?
3-Re-soldered transformer leads. This did not fix the problem.
4-Replaced a few capacitors on the power/inverter board shown as A,B and C.
5-I checked the 4 bulbs using my home-made bulb checker. All 4 bulbs seemed to be "ok".
At this point i would normally just replace "all" the caps on the board but in this case there are a few caps on the board that i dont have so replacing all of them would have to wait until after i order parts. I woud rather not do this unless i have to.
Any one have any suggestions on what to do to figure out the problem?
Pin1=>17v
Pin2=>17V
Pin3=>0.006V
Pin4=>0.006V
Pin5=>0.006V
Pin6=>5.11V
Pin7=>5.11V
Pin8=>0.038V
Pin9=>4.6V
