Re: Sharp Aquos LC-46D64U stand by with new boards!
The small AC input board that you attached a picture of 3 messages ago, does not convert the power to DC (I dont see a bridge rectifier on that board), so it must feed the power supply with AC power. Thus you could set your multimeter to 750v ~ (AC is symbolized by ~), and see what voltage the 2 metal pins running to the socket on the power supply board are getting (the socket is marked ACI) , you can position red on 1 pin, black on the other, order isnt very important. Be carefull not to bridge the 2 wires/ pins or touch either, as there will be a huge spark / destroy stuff, blow your breaker if you connect the white to black wire ...
BTW all the board should be connected, and the tv should be plugged in. You can take 1 reading with the TV off, and 1 with the TV on, although it shouldnt change.
