hi i got this samsung tv that would not power on so took back off and there was 2 blown caps on psu so changed them and bingo powers on but no picture and menu looks black plz see pics
samsung LE19R88BD
Re: samsung LE19R88BD
It will begin with "24" in the part #, list each you find and it might be possible to narrow it down. Can be on the bottom of the board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Looks like IC8001 is for the main applications processor, so I would try that one.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You should apply jumper, power set on. Set should turn on...
It will either freeze (stay with power light off or backlight on or something like that, but no image) or it will reboot (if it does this turn it off at the mains while it is on.)
After it does this you should remove the jumper.
Then go into service mode from standby press Info Menu Mute Power and set up all settings as required, to correct picture and tuner. may have to try a few times.
That is one method I have heard. I think there are a few others.
Should this fail you may have to replace the EEPROM with a blank one.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Might have to replace EEPROM then, I think the TV cannot recover it. (It is supposed to erase it.)
Also possible that you have another fault with the main board, and the EEPROM is fine.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostMight have to replace EEPROM then, I think the TV cannot recover it. (It is supposed to erase it.)
