magnavox 37mf337b/37 parts advice
    Re: magnavox 37mf337b/37 parts advice
    Parts are on the way! Checked D912 out of PSU it came back faulty. I will be using UF4007 diode for that replacement.P6KE120ACT ZD will be used for ZD902 ,and the three caps will be replaced with Panasonic EEU-FR1V102. Killian6pk, great point! Its alot easier to look at a pic than have to remember everything. I will update with progress as soon as parts are installed. Thanks again! Much appreciated!
      It is one of the reasons I press people to supply good clear pictures - they also
      help with future queries when parts are burnt out.
        ANYBODY OUT THERE CAN HELP ME WITH A PROBLEM WITH MY MAGNAVOX 37MF337B.. THE MAIN BOARD IS BAD OR SO I HAVE BEEN TOLD (PROIR TO THAT IT WAS A POWER SUPPLY WHICH AFTER I REPLACED IT THE REPAIR SHOP SAID IT IS NOW THE MAIN BOARD) I WAS LOOKING FOR ONE ON EBAY AND LOCATED A BOARD THAT THE GUY CALLED A T-CON BOARD PART # 6870C-0088D VER.1.. IT THIS THE BOARD i NEED ? BETTER YET, IF YOU CAN SEND ME TO A WEBSITE THAT WILL SHOW A SCHEMATIC, DIAGRAM OR LIST OF PARTS FOR MY TV SO I CAN "SEE" WHAT I AM LOOKING FOR.. I SEEN THIS BOARD BEFORE WHEN I BOUGHT MY POWER SUPPLY BUT CAN'T FIND IT NOW NOR KNOW THE LANGUAGE SO ANY HELP WOULDBE WELCOME.
          PLEASE DO NOT TALK IN CAPITAL LETTERS. IT MAKES IT SEEM LIKE YOU ARE SHOUTING.
          It sounds like the repair shop doesn't know what the fault is, I wouldn't trust them. They sound like they just swap boards rather than try to diagnose the problem.
          Here, I just uploaded the service manual:
          http://www.tgohome.com/ServiceManual...&Search=Submit
            I need help identifying, or finding a replacement zener diode.
            I cant find a free datasheet for crossreference, and I dont know enough to figure it out myself.
            Location(zd906) and part number(LT7228 P4KE250A)
              @ryan, that must be one those common failure diode in the snubber circuit, do not try to run without having new one installed.
              http://www.mouser.com/Search/Product...p%252btw%3D%3D
                Oops. I replaced the blown caps and powered on for 10 sec..
                Front led flashed fast and continuous red.
                I must have missed checking it first time through.
                Thank you for the link.
                Just curious- what usually happens when you run it.
                  hi, i have a very similar power supply board from a TV model number
                  (47MF437B/37 Phillips / Magnavox). The board is very similar. I have the same exact diode that is failing....P4KE250A.
                  also looking for a replacement diode for this?
