Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 05-17-2017, 04:21 AM   #1
String2016
City & State: quezon city
My Country: philippines
I'm a: Knowledge Seeker
Default Acer aspire one 722 bios needed
Hi everyone i need a working bios file for this acer aspire one 722 board id:P1VE6 LA-7071P Rev 1.0
String2016 is offline   Reply With Quote
Old 05-17-2017, 04:33 AM   #2
meritosari
meritosari's Avatar
City & State: Palangkaraya, Central Kalimantan
My Country: Indonesia
Line Voltage: 220VAC 50Hz
Default Re: Acer aspire one 722 bios needed
Try this:
meritosari is offline   Reply With Quote
Old 05-17-2017, 10:26 PM   #3
String2016
meritosari above bios not working netbook cannot turn on here is the original dump file can someone please fix this
Old 05-18-2017, 12:10 AM   #4
String2016
anyone please help
Old 05-18-2017, 01:01 AM   #5
mazloum
City & State: beirut
My Country: Lebanon
try this
mazloum is offline   Reply With Quote
Old 05-18-2017, 02:45 AM   #6
String2016
still the not working can someone fix my original dump please 3.3v present on bios and power button 19v 3v and 5volts are present in dc and coil
Old 05-18-2017, 06:05 AM   #7
String2016
anyone please help
Old 05-18-2017, 05:18 PM   #8
String2016
Anyone please help
Old 05-18-2017, 06:22 PM   #9
meritosari
meritosari's Avatar
I always use my bios above to flash AO722 and that's work, That bios taken from acer, the latest end version.
So, Probably it's not bios issue. Please don't judge all problem laptop always related bios corrupt or bad.
For this Platform, The Always Voltages present after plug in adapter, or in S5 state i.e VIN, B+, +RTCBATT, +VSB, +5VALW, +1.1VALW, and +3VALW. Make sure All present.
Also check ACIN and LID_SW# signals should be present after plug in adapter.
ON/OFFBTN# present and act like this if you've pressed 3.3V-----0V-----3.3V
after that EC_RSMRST# and PBTN_OUT# appears for give command FCH that all system was ready and could be to TURN ON.
I believe we all have been busy with each problems on bench ourselves. But Start reading some thread on this forum to increase your knowledges. Take some hours in everyday.
Old 05-18-2017, 10:41 PM   #10
String2016
Thanks for the response do you have schematic for this please
Old 05-19-2017, 08:29 PM   #11
meritosari
meritosari's Avatar
Last night I've managed to fix AO722 with can't power On problem.
Current Amp Drawn on my adapter+ (have been combined with DC Ammeter so it be able to monitor current if display come out, charging proccess, and will shut off if 19V rails was shorted. (features built in on original adapter)
0.0235A
Some reading of measurements :
Resistance to GND in Diode mode (DT9205D) more fast reading than Ohm mode, measurement without APPLYING POWER to the board.
PJ5 (+VSB) = 0.735
PJ1 (+3VALW) = 0.593
PJ3 (+5VALW) = 0.662
PJ2 (+1.1ALW) = 0.292
PJ6 (0.75VS) = 0.132
PJ9 (+1.05V) = 0.290
PJ7 (+1.8VS = 0.382
PJ4 (+1.05VS) = 0.059
PL16 (Apu_NB) = 0.012
PL17 (Apu core) = 0.283
U14 (1,2,3) = 0.961
U15 (1,2,3) = 0.513
U16 (1,2,3) = 0.094
Voltages reading APPLYING POWER
PJ5 (+VSB) = 18.80V
PJ1 (+3VALW) = 3.362V
PJ3 (+5VALW) = 5.11V
PJ2 (+1.1ALW) = 1.205V
PJ6 (0.75VS) = ~*
PJ9 (+1.05V) = ~*
PJ7 (+1.8VS = ~*
PJ4 (+1.05VS) = ~*
PL16 (Apu_NB) = ~*
PL17 (Apu core) = ~*
U14 (1,2,3) = ~*
U15 (1,2,3) = ~*
U16 (1,2,3) = ~*
PQ3 (2) = 4.85V (POK)
U9 (3) = 3.3V (LID_SW#)
PQ13 (1/output) = 0V (PACIN and ACIN) NG*
PQ1 (1,2,3) = ~18V NG*
VMB/BATT+ = 18.81V NG*
SW1 = 17.96V NG*
B+ (PR20) = 18.81V (VOLTAGE PRESENT but Low resistance/0.178 realize after know that PR26 was open, probably kill the battery) NG*
PR26 = open
PU2 (24) = shorted to GND
NG* = Not Good
~* = Can't Switch ON
schematic:
http://www.s-manuals.com/notebook/acer_aspire_one_ao722
datasheets (to know pin out):
http://rohmfs.rohm.com/en/products/d...5euat106-e.pdf
https://www.diodes.com/assets/Datasheets/AH180N.pdf
https://4donline.ihs.com/images/VipM...A73243A3159BB0
http://www.vishay.com/docs/71411/tp0610k.pdf
https://www.diodes.com/assets/Datasheets/ds31232.pdf
Solution:
Replace PR26 10ohm / 10_1206_5%
Replace PU2 ISL6251AHAZ
current drawn on my adapter 0.0092A after fix it
Test laptop couple hours, will update soon.
Hope will help you!
Old 05-20-2017, 08:58 AM   #12
String2016
Thanks for the schematic and info meritosari
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
