Okay,
I have read tons of info on these cells. And while there is an inherent danger to using different cells for different applications I am curious about something that really need to have some solid evidence on.
I have a drill battery pack and it contains some INR high discharge cells which are "designed for power tools" and I have some laptop cells that are designed more geared for capacity rather than high discharge.
Are you supposed to use them no you are not according to what I have read and I am not telling anyone to do it either this is strictly theory.
Now here is the other key element of the battery pack you have the battery control system.
Is it not true that the battery control system is designed to monitor health of a battery while in use or while being charged in all cases?
If this is so than would the odds be that explosions would not result from using this battery in my drill the BCS does not know chemistry it just knows battery voltages, and temps I know this is true.
I have a feeling that someone will chime in and say something to the order of don't do it if the BCS fails than you are screwed or it's your life or whatever do not do it but the real question is if the BCS fails in any occasion I have seen the battery does not work and if there were some quirky thing that would go wrong and allow the battery to keep running it would do the same thing no matter which cell you put into the pack right?
The IMR or INR based cells may be able to tolerate it a little better but in truth how much of a percentage safer would you be in that case using a high discharge or not my guess is your safety would be roughly the same in any case if all of the safety fails just enough to let this occur you may have a very small percentage of a chance that your battery being an imr/inr is going to save you because it all boils down to well boiling point the electrolyte is going to vent out no matter what at the same temps right?
So would my theory be correct or is there something more to this that I am missing ? I am not asking for someone to tell me its OK I just want to know if I am understanding what I am reading correctly.
DO NOT TRY THIS IT IS ONLY THEORY AND DISCUSSION!
Results are pretty ugly when these things go. They look like this:
