I have a Toshiba Satellite L355-S7831 laptop that came in with major system problems and would not repair itself. Turned out the hard drive, a Hitachi 5K320-250, was failing and after several runs (days!) of HDD Regenerator, it finally settled down.
With Vista (Home Premium) being the pig it is, I went looking and found a Toshiba Windows 7 Ultimate .iso, with SLIC 2.1, and installed it. The system ran much better, but there was still the failing disk to worry about.
Located a comparable, new, WD Black WD2500BEKT drive and used Acronis True Image Home to clone the drive. Used the files method not the sector-by-sector approach as I didn't want to transfer pseudo bad sectors to the new disk.
Worked perfectly and several full disk checks have shown no errors. The system is also noticeably faster as the original HD was 5400 rpm and the new one is 7200 rpm.
Now, the questions are:
What purpose does the "TOSHIBA RECOVERY VOLUME" that is in a 1.5 GB partition at the beginning of the disk serve?
Is it unneeded as the system is now Windows 7 not Vista?
CAN it safely be removed (by repartitioning) without crashing the present W7 install?
SHOULD it be removed in case there is an error and W7 tries to use it thinking it's VHP?
Your thoughts and recommendations, please.
Toast
Toast
