Look at this - super tiny fans!!!
    I was watching the EEVBlog when i noticed this on the side:
    http://www.digikey.com/us/en/ph/Suno...yMiniFans.html
    http://search.digikey.com/scripts/dk...part=UF385-100
    8x8x5mm, now that's a ridiculously tiny fan. And 14k RPM at 3 volts! Insane. I bet that thing flies if it's left on its own... But it sure doesn't come cheap. The slightly larger models are cheaper, say this: http://search.digikey.com/scripts/dk...part=UF3C3-500 12x12x3mm. 16500 rpm. And a staggering... 0.2 CFM.
    Can you say WHEEEEEEEEEEEEE ???
    A working TV? How boring!
    Re: Look at this - super tiny fans!!!
    1 50.75000 50.75
    Yea....at 50 bucks a piece, I'll run right out and buy a bunch of those....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      I have a few these of various tiny sizes and while they dont move alot of air sometimes just moving a little bit of air helps, esp when you are talking about a switch/router or nas that you cant live without.
        hahaha. The 2nd one (the 12mm one) doesn't even mention the noise. I bet at 16k rpm it sounds like a 747 taking off. Erm, on 2nd thoughts, it must be even louder. The Rolls Royce RB211 only spins at just under 4k RPM at full throttle.
          I had a tiny (well, not this tiny, i think it was 30x30x10mm) fan recovered from an old laptop. It originally ran at 5v. I ran it at 20v. It took off and started flying. Unfortunately it quickly got that familiar smell... so i stopped it as not to burn it. Still have it somewhere, not that i'd have any use for such a noisemaker.
            Now stack about 100 of them on the heatsink of a 3.2 GHz Pentium 4 Prescott and try to play Crysis without going deaf . Anyone?
            I should try that too. I have a box full of old Pentium 2 laptops and I think 1 or 2 are not working.
              I saw those things a while ago, but I can't remember where...
              Wow. I wish I was there to see that.
              Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
              I have two v2s and one v1.
              I am still looking at these boards nearly every day.
              What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                Not even close. It's rated at 17.3 dBA at .3 meter. That's well below whisper level.
                PlainBill
                  OK. I couldn't find any mention of the noise on the datasheet.
                    Generated noise is proportional with blade area in contact with moving air.
                    Because is that small, it will not move much air, so very little noise.
                    That Rolls Royce RB211 fan is moving slowly, but moves a lot more air through it, that's why is a lot louder. It has a diameter between 1.86 and 2.19 meter
                      I know, I was joking. (which is why the ). Of course a jet engine would be louder.
                        But it would still be like "wheeeeeee" when you do notice it. Not only the level but also the frequency matters... And small fans are likely to emit a high-pitched whine instead of just a buzz.
                          True. But consider the numbers. 30dBA is 'A whisper in a quiet library'. This is 17.1 dBA at 30 cm. And since the dBA scale is logarithmic, this would be less than half as loud. I think an approximate analogy would be a baby mosquito at arms length. Of course, at $50 each, you wouldn't want to swat one....
                          PlainBill
                            So far as I know, 3dB less is half the initial value.
                            17dB will be several waaaay less than 30dB ...
                              Mechanical mosquito.
                              Find Nedry!
                              Check the Vending machines!!
                              <----Computer says I need more beer.
