Hi i have a samsung ue40d6510 which comes on fine but after 10-15secs turns itself off. It does not come straight back on unless turned on by the remote/on button. Ive checked the caps but none are bulging.
SAMSUNG ue40d6510 TURNING OFF AFTER 15secs
Re: SAMSUNG ue40d6510 TURNING OFF AFTER 15secs
Originally posted by andrews7523 View PostIve unplugged the Tv whilst turnt on and the Tv goes off
Re read my other post again. A PSU with a pull up resistor doesn't need the main board with the power button to turn on the backlight.
OK, the power supply/LED driver board has built-in pull-up resistors to allow you to do the self test of the power supply and the LED driver circuit without the need of the main board. So unplug the TV from the outlet, then unhook the cable between the power supply and the main board, plug the TV AC plug into the outlet, then you should see the backlights come on and stay on as long as the TV is plugged into the AC outlet (the main board is not active at this point).
If the backlights stay on then you know the power supply, LED driver, and the Backlights LEDs are OK, if not then you need to do more troubleshooting of the power supply circuits, LED driver circuits, and testing of the LEDs.Last edited by budm; 11-25-2015, 07:01 PM.Never stop learning
un-plug main board ............ plug tv in and it does a self test and the backlights will come on like magic see if they stay on
its a self test ciruit built into the power supply just un-plug main board nothing else then plug into mains supply simple
Right gonna give this one last try.
Main Board = the one with the HDMI inputs etc.
Power supply = the one with that connects to the plug.
The power supply and mainboard have a wire connecting both together.
Remove the wire (or just take out one end so they are no longer connected.)
Right guys sorry for the blonde moment. Tried this and no Backlights come on. What should i try check next, caps, diodes, resistors. Also maybe worth a mention that the Tv clicks when coming on and turning off but I've never come across this before.
what you are saying doest make sense,
if the tv turns on for 15 seconds, then with the mainboard unplgged the backlight should at least appear for 15 seconds...
once the mainboard is disconnected from the power supply you need to plug back in the tv to the AC socket.
