OK, I found pictures of the board AY128D-4SF51 which looks really close to your board AY128D-4SF11.
As you can see, CON3 has the pin labels on the bottom side of the board, so I need to know what the Voltages are (yo post the Voltage readings but did not assign pin numbers or the pin name with the readings).
I need to find out if you do have >2.5VDC on pin 5 (PS-ON) or not, and the Voltage readings of the rest of the pins.
Pictures provided by SHOPJIMMY.
1 (GND)
2 (GND)
3 (+5V) =
4 (+5V) =
5 (PS-ON) =
6 (+5VSB) =
7 (+5) =
8 (+5) =
9 (GND)
10 (GND)
11 (GND)
12 (+12V) =
13 (+12V) =
L2 is the PFC inductor, the PFC and L2 are OK otherwise you will not have the 384V DC on the cap. https://www.badcaps.net/forum/attach...0&d=1448075181
In the picture you show 173VDC on C13, you had indicated you were using the negative leg of the as the GND ref for the meter in post 1., but now you have 384VDC.
