Hello
I have an Insignia NS-L32Q-10A. When it is powered up, the standby LED changes from RED to BLUE. The screen flashes on and off after once second. The audio works with no issues. In reading previous posts, I took readings across the startup cap with the following results:
TV in standby - 85V
TV powered on-330V.
This is a 120uF/450V Cap. According to previous posts, it seems that these readings may be low as they typically seem to be 165V/400V. Is the CAP bad or being loaded down? Also, there is a 6 PIN connector on the PS to the inverter board that reads no voltages on any pins. There are also no outputs printed on the circuit board. Should there be voltages present? Any suggestions where I should be looking?
Thanks in advance!
TV in standby - 85V
TV powered on-330V.
Thanks in advance!
