Re: Hp 1955
Thanks both for help!
The fuse behaves as mentioned obove. It doesn't seem to be a fuse problem.
Sometimes good to controll the obvious. I'm sure it was switched on.
Are you sure about what you said above selldoor? When switched of the DMM reads OL and when on it reads 0.
But does it seem that the rectifier is working, why did I get weird numbers on the DMM when testing in ohm mode?
Set the DMM on 200 ohm scale and put one probe on each leg of the fuse. You should get a reading less than 1 ohm (same as touching the two probes together).
Whilst looking for an easy way to show this I noticed that this board has a switch. When you were testing the BIG Cap
was it definitely switched on?
same as the fuse but obviously resistance when on and none when off
