The hp 1955 (Benq 48.L1A02.A00) the monitor was just totaly dead.
So I opened it and removed the power board. So I found out that one of the three pins on the power cable connector was blown. If you look at the "green" side its the left pin. the center pin was loose and the right pin had cracked solder. So I resoledered it. I think I did I decent job on that but it didn't help at all. The power led didn't go on. also here is no bulging on capacitators or something similar. What do you think, could it be both the C5707 transistors and the picofuse maybe?
