Re: Samsung 930B re-capped, no backlight
I have a 939B that is not working.
All the 10mm and smaller caps have been replaced they were obviously swollen. And have been replaced this includes the two 4MM caps.
U202 and U203 had similar damage as the OP board. And have been replaced.
I have a power supply that is starting and shutting off repeatedly, the power LED is flashing on and off
I am currently looking at the DM0565R power switch
http://pdf1.alldatasheet.com/datashe...SDM0565RB.html
I have taken some voltage measurements
Pin 1 is fluctuating between 150 and 160V D.C.
Pin 2 dose have a ground
Pin 3 is fluctuating between 9 and 15V D.C.
Pin 4 which is the feed Back is Fluctuating between .5 And 8 V D.C.
Pin 5 not used
Pin 6 is fluctuating between 32V D.C. and 159 V D.C.
I guess i should have said anybody got any ideas on what to check
Pin 5 not used
