Re: Thermal compounds / pads and thermal conductivity.
Ah, I see the picture now.
The fact that it is an AMD board is part of the reason why, as the CPU heatsink can only be oriented to pull or push air up. So I see why that's a problem now. We had problems like that we a few new Ryzen boards in the last place I worked. It wasn't until Cooler Master released a proper bracket that allowed us to flip the whole heatsink 90° so that we could avoid this problem. So before then, we also often encountered the same problem as you.
Yup, nothing you can do about it.
Hopefully, the PSU has a 120/140 mm fan so you can point the CPU heatsink fan to exhaust the hot air through the PSU. Not the best solution, but it should keep the heat out of the case. If the PSU is a good brand, it should take it without any problems.
Not exactly.
AMD's hope with those APUs at the time was to bring affordable gaming PCs with decent 1080p performance in already released game titles. And for the most part, those APUs did that fairly well, managing 30-40 FPS at 1080p, medium-high settings. Of course when the newer generation of games came out, these APUs could not quite keep up with them.
So those APUs are good for playing games that came before or right around the same time as the APUs themselves. But any games released after them may not play that well.
That said, modern high-end CPU and discrete GPU will no-doubt mop the floor with an APU like that. But again, for what it's worth, those APUs did fairly well.
So scratch out what I said above about the CPU fan exhausting hot air into the PSU.
That said, what brand is the PSU?
You don't need a very fast CPU these days for gaming. Even a mid-range i5 will be more than enough to run anything with very good frame rates. The GPU pretty much takes care of all that. Slap a GTX 1060/1070/1080 in that PC, and I bet it will fly in games again... though I don't really suggest you do that now if the PSU is some no-name crap. If it is, it might take a 1050 at best, and that's not exactly a high-end gaming video card (though still adequate for a lot of stuff).
Yeah, I know that situation.
You are doing good in helping him - really shows that you are a nice person. That said, be careful, as some people will use that to take advantage of you. When they do, it's time to tell them what's what. And if they complain that you are overreacting or something... that's their problem.
Originally posted by Spork Schivago
View Post
View Post
View Post
View Post
View Post
